Truck died suddenly
I was drive down the street the other day,truck was running great. But when I got in the turning lane and started to take off it just died on me. now she don't want to fire up.Darn near killed my battery trying to get it started with no luck. The low fuel light came on just as I went to make the turn.So had a friend pick me up take me to the gas station three times cause I only had a 1gal gas-can. but still wont start she turns over just wont fire up. Never pit or sputtered nothing just stopped running. Any advise or suggestion ? Had my daughter get in and turn the to on position,while I stood at the tank listening for the fuel pump. but didnt hear it kick on. I'm hoping its not the fuel pump
Well if you can't hear it run then it's either the pump or an issue with power not getting to it. Have you checked the fuse? The fuse is #19 in the under hood fuse box, not the fuse box under the dash.
Truck just stopped running
I was drive down the street the other day,truck was running great. But when I got in the turning lane and started to take off it just died on me. now she don't want to fire up.Darn near killed my battery trying to get it started with no luck. The low fuel light came on just as I went to make the turn.So had a friend pick me up take me to the gas station three times cause I only had a 1gal gas-can. but still wont start she turns over just wont fire up. Never spit or sputtered nothing just stopped running. Any advise or suggestion ? Had my daughter get in and turn the to on position,while I stood at the tank listening for the fuel pump. but didnt hear it kick on. I'm hoping its not the fuel pump But knowing my luck it will be ,it couldn't just be something simple like the fuel pump reset(shut off)
switch or a fuse :- huh
HeathJohnson
Modular V10 (6.8l)
12-19-2006 07:18 AM
