wont stay running help!!
Ok as long as the key is held in the start position it will run but when i let it kick back to run position it dies.... Things I've replaced.....
Battery
ground cable
starter relay
starter
ecm/pcm
fuel pressure regulator
spark plugs
retimed
key lock cylinder
ignition switch
im getting 35 psi fuel pressure (while cranking and not)
I had ignition control module tested and it passed
I'm so clueless
Battery
ground cable
starter relay
starter
ecm/pcm
spark plugs
retimed
key lock cylinder
ignition switch
I'm so clueless
cfassett87
06-25-2012 08:49 AM
Chequamegon
1999 to 2016 Super Duty
08-11-2011 10:47 PM
noorder
Electrical Systems/Wiring
05-13-2007 02:02 PM
