increasing power on 1986 F250 6.9
Received 3,106 Likes
on
I just picked up an 84 F-250 with the 6.9, and was also thinking of turning up the fuel just enough to get the haze at wot, just not quite sure how the turn it up. Does anyone have a picture of where the screw is on the ip?
I'm also planning up opening the exhaust, and probably using a high flow muffler instead of deleting muffler entirely. I've heard 4"-4.5" exhaust is a good size, gives a nice tone and opens it up enough, w/o being ridiculously large.
i'm planning to turbo mine one of these days, but thats to the tune of a few thousand bucks, so not gonna fit the OP. and after that, i intend to get myself a gearvendors overdrive unit to further enhance my economy.
@realtrucksrattle, there is a cover just under the oil fill that you remove, and there is (i'm told) a screw there in the center of the IP's drive gear (IIRC) that you turn in to increase the fuel or out to reduce the fuel.
hope that helps
...and since you're new, IP=injection pump, IIRC=if i remember correctly, just in case you weren't up on the local lingo
hope that helps
on
hope that helps
hope that helps
before you turn up the fuel, you should get a pyrometer to watch the exhaust temps. if they go over 1200 degrees you risk engine damage.
VaFordman26
20
07-29-2015 04:09 PM
