Power for additional lock actuators
#31
#36
#37
Sam
#38
Duane, you say that the BCM:
By this I assume you mean that 1 second pulse is a 12+V pulse. According to your crude wiring diagram with your 4 relay's, this looks to be true. However, looking at post #19, + is connected to pin 86 of the relay, which would mean the lock/unlock triggers would have to go to ground for it to work.
I plan to do this mod so that I can lock/unlock all the doors on my service body with the key fob, and just wanted to clarify this one point before I get started. Thanks for all the info you posted.
Rick
sends an approximately 1 second pulse to the lock motor
Rick
#39
I'm not sure about post 19, at first glance, it doesn't look like it will work.
#41
That drawing is only supplying 12volts + to a single terminal.
The solenoids need + & - and they need to be able to reverse those circuits.
rangerjoey76
Electrical Systems/Wiring
04-14-2019 07:43 AM
Dean06919
04-19-2016 10:49 AM
