engine change 1967
Old Mar 16, 2011 | 03:57 PM
darcast67's Avatar
darcast67
engine change 1967
hello
I have a 1967 f100 with 352 motor
I want to change for a 302
can be done easily?
I should do?
thanks
Old Mar 16, 2011 | 04:04 PM
limegoldf100's Avatar
limegoldf100
Engine perches are different. Transmission or bellhousing not the same, so you have to use one with the small-block pattern (240/300 six, 302, 351W, 351C). You may have to change the driveshaft length, depending on the transmission.
Old Mar 16, 2011 | 04:18 PM
darcast67's Avatar
darcast67
thanks
engine 302 is a 1970 ford bronco
the trasmission t 18 fit?
Old Mar 18, 2011 | 12:12 AM
jhooch's Avatar
jhooch
WIth the correct bellhousing yes. Your FE bellhousing will not mate to the 302.
