code help
Old Mar 16, 2011 | 02:46 PM
chicagodragon's Avatar
chicagodragon
code help
I pulled 3 codes on my truck today. Po344,,po470 and1211. I lloked. Them up on the sticky.but have no idea. Help
Old Mar 16, 2011 | 02:57 PM
Talyn's Avatar
Talyn
1211 is DC/PSI over/under desired If I remember.
Not a big one.
Means you got on the go pedal a bit and the hpop cannot keep up.
Old Mar 16, 2011 | 02:58 PM
Talyn's Avatar
Talyn
Not a big one.
Old Mar 16, 2011 | 02:59 PM
plgebbia's Avatar
plgebbia
P0344-CMP Camshaft pos sensor ckt intermittent Incorrect number of CMP transition counts Harness routing, charging ckt, sensor, int ckt, improper gap
P0470-EBP Exhst press sensor ckt malfnct (96 MY) No-start or crank mode Biased sensor, open signal return
P1211-IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
Sounds like you might need to change the CPS and clear the codes and see if they come back.
Old Mar 16, 2011 | 03:10 PM
427 fordman's Avatar
427 fordman
0470 is probably because your ebpv is unplugged
1211 could be like william said, I used to get that code before my hpop change
0344, cam sensor or check over the wiring close too.
I think I'm somewhat right here...
Old Mar 16, 2011 | 03:16 PM
chicagodragon
The baxkpressure code is Just the tube on the front of the engine I never cleaned out ?
Old Mar 16, 2011 | 03:27 PM
427 fordman
If your ebpv is unplugged, that'll set the code, and you don't need the tube at all. It can be removed and plugged at the manifold if you wish ( if your ebpv is unplugged or deleted). Or just leave it. I didn't know this and ended up overnighting a new tube as I bleeped my threads up and neeeded the truck. Found out later, after 50 bucks of air freight...
itsunday25
Jul 7, 2011 05:22 PM
fredo181
Modular V10 (6.8l)
Sep 15, 2009 10:08 AM
carp_886
Nov 3, 2007 10:31 PM
tmartinford
New Member Introductions
Apr 2, 2007 01:43 PM
gizmo13
Aug 14, 2004 07:58 PM
