Need help ID ing rear axle - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 03-15-2011, 05:59 PM
80broncoman
80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.80broncoman is gaining momentum as a positive member of FTE.
This axle is in my 1994 F-700.
What the heck is this rear axle I though it would be simple but no so.
First the door tag is blank where the rear axle code should be. it does say its has a 22,700 lb rating
It is a Eaton rear end in my truck. It looks to be the factory axle Here is all the info off the rear end. Stamped into a stainless tag on the housing:
PT No 303126 HSG model 22A ser No G-2247055
Stenciled into the center casting: 88516 G1973 5*29
Casting numbers found are (Bottom flange 67802) (verticle TD22) and (top upside down 3441106) are on the center casting.
I lknow it has 5.29 gears in it. I am looking for some 3.90 gears or a center section with 3.90 gears.
Any one have an idea??
Old 03-16-2011, 10:58 AM
80broncoman
After spending a few hours of online searching
I found it.
Its a 22 series (99% sure its a #22121)
this page has the info
(Go to the last link at the bottom of the list.!!)
LiteratureCenterResults
Old 03-16-2011, 01:01 PM
85e150six4mtod
85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
That's quite a link with tons of info.
Old 03-16-2011, 02:32 PM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Per your suggestion, I took that link and put in the TECH folder at the top of this forum.
Great stuff!
Old 03-16-2011, 07:34 PM
80broncoman
Great stuff!
I was thinking about that last night. i just forgot to mention it.
Old 03-17-2011, 07:43 AM
Krewat's Avatar
Krewat
Krewat is offline
Rep points for the great find
Old 04-26-2011, 09:01 PM
80broncoman
just I'd tell how it turned out in case some searched it out.
I found a New 3.70 "take-out" gear set in portland or. for $250 +38 to ship to Ohio
MUCH better than what I had expected.
And I found out almost exactly what I have a 22 series axle housing (22K lb axle rating)and axle shafts. and a 17 or 18 series 2 speed gear set in a single speed housing??!?
I may have to buy a bolt kit or a carrier, but will only know when its apart.
Old 07-13-2011, 05:41 PM
80broncoman
well to tell the rest of the story:
The gear swap was completed a few weeks ago and as of last week I now have the new low profile tires installed.
I foud out I had a 22 series axle housing, hubs, axle shafts and
A 17,18,19 series carrier , pumpkin, and gears.
I bought the 3.70 ratio gear set and needed carrier from anderson bros in portland.
I had to get a yoke locally as mine had what someone called a wing style yoke on it.
the 3.70 gears had larger spline dia than the old 5.29 gears did.
The new stup is 3.70 gear and 36.5 inch tall tire. it really works well.
Old 09-16-2011, 09:25 AM
mrblonde108's Avatar
mrblonde108
mrblonde108 is offline
mrblonde108 is starting off with a positive reputation.
How much did gear swap cost in total? I have a 2 speed rear and it has 4.56/ 6.34 and that's the tallest they offer on that eton link there.
Old 09-16-2011, 05:16 PM
80broncoman
Mine was right at $500 because I paid a friend of mine to set it up and install the chunk. (I don't have a garage)
I lucked out on the gears finding a good set for $250. but the internet is how I found them.
I also bought a Eaton part book off ebaay for $8 dollars. it had some part numbers in it that were not on the site.
Some one must have burned up the stock 4.88 rear in my truck. because everything i've been told and seen says the axle is from the early 1970s. it still has the larger later model brakes(anti lock sensors still attacked) but the the 5.29 gears and center housing came up 70s every where I looked.
The one place that has a lot of older eaton parts is anderson brothers in portland.
68Rookie
13
11-05-2016 08:49 AM
abosely
03-27-2016 05:37 PM
mzerega
Large Truck
06-06-2014 12:36 PM
1990_Bronco_Custom
1978 - 1996 Big Bronco
01-11-2012 09:27 AM
ferrwrench
01-22-2008 08:07 PM
Quick Reply: Need help ID ing rear axle
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
