gpr question
gpr question
My baby is romping in 40* weather. I put new glow plugs in about 2 years ago. I haven't ohm'd them to test yet. I used a volt meter to check my gpr and it turns on. It stays on for 1 minute.
I thought I read on here that it is supposed to stay on for 2 minutes.
Can somebody correct me if I'm wrong?
And where can I get a gpr led?
Looks like you've been around FTE a while, so you're probably familiar with the $.50 mod. If you haven't done the mod, I could see one end of the UVCH connection working loose, causing you to lose one or two glow plug connections. Or, GPR was stuck on at some point, and burned out one or more plugs. Or, maybe just a Motorcraft that died too soon.
Wow, BJ. So, you've got voltage coming from the GPR, and you've got proper resistance for each glow plug at the UVCH. I would ohm each glow plug lead from the UVCH connection back to the output post on the GPR. Also, I have heard of GPR relays working intermittently. Perhaps the times you metered the GPR output it was working, but isn't other times? One other thing - have you changed to a heavier oil since last year?
I was wondering if it just happened to work the couple times I tested it and not on other times. I'm going to go ahead and pick up another one. I don't know how long that one has been in the truck. It was there when I got it about 3 years ago.
The oil was just changed recently but I don't remember what I put in it now.
On a side note when I pulled the intake tube to ohm the gp's I saw that my compressor wheel is in real bad shape. It has no play in the shaft so I guess when the filter that came with my mac intake came apart it ate up the wheel. So I ordered a few more parts
miranda machining
03-23-2018 05:04 PM
Ridgerunner500
13
02-04-2008 06:01 AM
