Best lift kit for a 1994 f150
  #31
Old 10-21-2017, 09:21 PM
Fordcountry101's Avatar
Fordcountry101
Fordcountry101 is offline
I have a 94 f150 with the i6 300 and want to do a 4 inch lift with 33s. This truck is going to be a work truck and I wanted to know how the i6 with the lift would do when towing or with a load of firewood?
  #32
Old 10-22-2017, 11:16 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Welcome to the forum, but you would be far better off starting a new thread with your question.
There are quite a few variables
Tire size, rear ratio, truck configuration(cab and bed size), which transmission, what size trailer you plan on towing, etc
  #33
Old 10-29-2017, 07:22 PM
MFJ's Avatar
MFJ
MFJ is offline
You will be cursing when you load it down if you lift it and add 33s. I have a F150, 300, 2wd, stock size tires and it's a bit slow unloaded. Removing mechanical advantage with the bigger tires doesn't help, unless you regear to 4:11 or deeper. Lifting it also means you have to hoist the wood or whatever higher up just to get it in the box.
I feel that if you want tires bigger than 31s, go right for a F350. Better axles, frame, brakes, etc.
1994FordF-350MegaCab
10-21-2018 08:01 PM
bullyben
Large Truck
09-16-2017 09:26 PM
Jim40216
03-03-2017 10:50 AM
Bat4x4
2017+ Super Duty
02-05-2017 10:05 PM
Mread22
03-13-2016 10:23 PM
Quick Reply: Best lift kit for a 1994 f150
