What can you tell me about the F-3's?
Thanks for all of the ideas guys. I guess I'd like to go with the least expensive route because I'm in high school and don't have alot of money to spare. Would it be easiest to find a set of 17.5 inch wheels from a 56 to mid 60's from an f-250? I may be able to borrow the rear brake setup from my uncle's 48-50 Ford panel/ delivery truck. I'm not really sure what you'd call it, or if it's got 12 inch rear drums. I think it'd be nice if I could find the 17.5 inch rims, but I'm not sure how easy it will be to find them.
Well.. a few months later and I still don't have a solution. I would really LOVE to avoid buying a new set of rims, but if these are extremely dangerous, I guess they'll have to go. I emailed Pioneer Rim & Wheel out of Minneapolis to see if they would be able to order a set of rims that would work. Are you guys certain that there are no modern replacements being manufactured? This truck is just turning out to be a bigger project than I ever imagined. I've already rebuilt the rear wheel cylinders, so rims are my next priority. I wouldn't be in such a hurry about the rims, but my tires don't even hold air anymore, so I NEED to find replacements in order to move the truck. I wish I could find a place around Duluth who would at least put a used set of tires on the rims so I could at least be able to move it.
The bolt pattern isn't the problem. But the drums on the 48-50 1 ton rear brakes are a larger diameter than what typical 16" wheels will fit over.
#28
I got a set of 16.5 inch rims, two of which seemed like they were deep enough for the drums to clear, but they weren't. I figured I might as well put the front ones on to see how they look, but I really do NOT like the look of them. They just look too small! I can't stand it. So I think I'm going to head around to all of the junkyards and try to find some 17.5 inch rims from the 56 to 69 f-250's. I know I'm jumping around an awful lot, but I want this truck to look fairly correct. I considered swapping the rear end out for a dana 60, but that would only be so I could use 16 inch rims. Now that I know how smaller rims look, I don't think I'm going with that option. Eventually, I think I'll probably switch out the rear end just to make it more practical to drive, but I don't have the money right now. Speaking of which, what kind of top speed could I expect out of this truck? It's got a 4 speed with the flathead v8 if I hadn't mentioned that before.
#29
#30
top speed
