Service engine soon on ?
Old 03-02-2011, 05:51 PM
gjf's Avatar
gjf
gjf is offline
Hi ,i am new here my 2003 f 150 4x4 started to get a slight miss. Than the service engine light came on and is still on. It is real notice able in top gear @ low rpms . It has a slight buck to it. The truck has been well maintained . Any help ?
Milage 144,000
moter 4.6
Thanks gjf
George
Old 03-02-2011, 06:15 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Get your codes read.
Old 03-03-2011, 02:41 PM
gjf's Avatar
gjf
gjf is offline
Took it to the ford dealer. They put it on there machine . It came up # 5 coil was not fireing the plug. They changed the coil & plug.
gjf
Old 03-03-2011, 03:39 PM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
man you wasted some $$$ , you could have gotten the codes read at autozone or an autoparts store, bought the plugs and cop there if they were both bad and saved you a ton of $$$
Old 03-16-2011, 02:27 AM
airbornedude's Avatar
airbornedude
airbornedude is offline
service engine soon on ?
Hey BlitZ- Maybe he figured since he was at the "stealer" already, why not have the work done or he needed his ride asap for work or travel. Whatever, like you said, we are here to help him, like I got helped.
Airbornedude.
Old 03-16-2011, 06:21 PM
whitefordexplorer's Avatar
whitefordexplorer
whitefordexplorer is offline
he will eventually replace all 8 coil packs. by the 3rd or 4th he will end up doing it himself.
Old 03-16-2011, 09:21 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
dont give him such a hard time. He said it has been well maintained. might have had new plugs and coils after 100k miles and the one coil just had a premature failure. HE has it replaced, might be good for 5 more years.
Old 03-18-2011, 09:41 PM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
I just hate to see someone waste money at the dealership when we could have helped them. In my case though it seems I may have to go to the dealership since i have no CEL and my idle dropping while stopping problem is driving me crazy lol. I am sure its not the IAC b/c the motor idles fine when the truck is sitting still, it when I get to about 700 Rpm when coming to a stop the idle does a free fall to 500Rpm comes back up to 650Rpm then it sounds like the engine goes veroom really low as the idle goes up to 750Rpm then back down to 650Rpm and stays there with no further change.
gjf250
General Automotive Discussion
01-20-2013 06:48 AM
gjf250
Paint & Bodywork
01-17-2013 08:02 PM
gjf250
Electrical Systems/Wiring
06-03-2012 07:36 PM
George M
05-08-2007 07:12 PM
Quick Reply: Service engine soon on ?
