Exhaust leak at up pipe
Both my up pipes are leaking where they join the Y at the back of the turbo. Any thoughts on best way to fix? From what I can tell neither Autozone or Oreilly's has parts/gaskets. The Haynes manual I have conveniently skips mention of the exhaust and up pipes. While this is my first post on here I have been on here ALOT learning all kinds of good info
Welcome to FTE.
The best fix is to install bellowed up-pipes to eliminate the donut gasket joint at that location. It's kind of pricey, but it's the last time you'll have to do it. The cheapest price seems to be here. Riffraff Diesel: IH Bellowed Up-pipe Kit and the instructions on how to change them are here Welcome to Pocket's International UP-Pipe Replacement Web Page
If the money is too tight to go that route, go back to your local auto parts store and tell them you need (2) Felpro 8194 donut gaskets. Don't tell them the make or model or anything else. Just say this is the part number I need. Felpro 8194. They will fit your up pipes. They are a little thicker than the stock ones, but they fit. Be sure and coat everything in anti-seize when you put it all back together.
Depending on what shape the pipes are in you may be able to get away with doing the fel-pro 8194 donuts. Otherwise the permanent fix is bellowed up pipes that eliminate the donuts. Riffraff Diesel has about the best price on them and you can get ceramic coated ones from Clay too.
EDIT: Slow Typing? Really? HA HA
You will not be able to tell if the up pipes are damaged until you get them apart. But if you find them damaged you can get replacements.
F81Z-6K854-EA (passenger side) $30.52
F81Z-6K854-FA (drivers side) $37.66 (Prices from Partsguyed.com----OEM BABY)
I couldn't think of the word "flared" and for some reason typed bellowed instead of beveled, oh well Ken got you lined out.
