The next thing on the "to do" list is to correct a pull to the right when I hit the brakes hard. It was there before the upgrades - not sure if it is the brakes or something else.
a couple of before and after pics......I'm still thinking about the 3 1/2" blocks for the rear or possibly some Firestone Airbags. Haven't done any homework on it though.
Still need some tire & rims.......
Tony Wildman Chip
reg return
injectors
turbo
etc.......
Very Nice! and yeah it looks a little high in the front, those blocks should fix that or the firestones.......if you plan to tow a heavy trailer then go w/ the air bags!
The dual setup from Cary has the shocks correctly valved for this application so I have not had the same issue. It's only been a day but I like it so far!
Good to know, looks like I'll be selling 2 sets of bilsteins soon. Thanks!
I am curious how your front body mounts are on this X? I have read that the gap between the bumper and fender is a pretty good indication of how the body mounts are holding up. I noticed you have a small gap on your X and made me curious if the myth is true.
You can see mine has a bigger gap but I haven't had the X home from storage yet to check the mounts to see what condition they are in.
I am curious how your front body mounts are on this X? I have read that the gap between the bumper and fender is a pretty good indication of how the body mounts are holding up. I noticed you have a small gap on your X and made me curious if the myth is true.....
I'll take a peak next time I crawl underneath and see if I can tell.
