Backing in really tight spaces/power steering
If you are backing in a really tight space, as in, can only roll a few inches while you turn, how hard should it be to steer????
My arms were hurting backing out last night, I was told just now by the dealer, there is nothing wrong with the power steering (it has been worked on four times). That it is normal for these trucks because of how they are designed, that in that situation, put the truck in neutral and give it gas, then go.
Is this true???? I was told by one mechanic I needed new shocks, they say are the fine. I just dont know who to trust or believe.
to test if you need front shocks (which in your case would not help your hard steering) simply bounce a front corner of the truck, if it does not settle after 1 and 1/2 bounce, then you need new shocks.
on
You are saying don't ever change the fluid in the power steering ? If you had the fliud change by someone else other than yourself, they may have put "power steering" fluid in the reservoir instead of ATF ( mercon automatic transmission fluid, which is required)
No!! Lol I'm not saying don't ever get it changed. I took mine to a local place and had them change it for me and I don't like other people in my truck so I was turning the wheel back and fourth while they did it. I think I might have a problem, that thought didn't even dawn on me until you mentioned it I'm gonna call tomorrow and find out... I should have known better!!! Thanks for bringing that up bud.
what I am talking about is backing of out a really tight spot - say a 6 point turn - my foot was never on the brake as I was turning on the wheel but I was really not giving it any gas as I was only able to go back about a foot at a time - I asked a friend last night who has the same truck (but not with big tires) and he has the same issue.
The mechanic that has been working on my truck said it is just really a problem with the 01's, that is basically a flaw in the system for that year.
Never heard of this 'flaw'??? I must have one of those '01s that does not know she is 'flawed'???? I will let her know when I get out to the parking lot.
Better yet, maybe you need to get a mechanic who an't snowing you....
i have the same "problem." When I am stopped, i can get a turn and a half then it gets really hard, all i have to do is roll an inch and it turns to butter again. i think i hold the brake at the same time, i'll have to take notice and get back to you....but dont worry, mine gets hard after a turn, nearly impossible actually.
75F150360
21
12-25-2013 06:00 PM
Mike W
17
05-18-2002 08:41 PM
