My F-700 RV/jeep transport build thread
#31
I am plnning on some graphics that will look like the old 70s winnebago but have a U-RV on each side.
I plan to make some folding steps also
#33
It hasent moved yet. I didn't even start it since I buttoned it up this morning.
I am still planning on buy a pyrometer and a boost gauge. this month. if i do drive i'm not going anywhere just a test drive.
For those wondering what we are talking about, I gave a little (40HP or so? )tune-UP. with nevrenufhp's help.
I'll post up the results.
#36
Cool truck/camper! I plan on doing something similar with my '80 C-8000.You have given me a bunch of good ideas! Thanks for posting your progress.My powertrain consists of: 3208 Cat NA-175hp,Allison MT-653 (5-speed auto),Eaton 5.43 ratio RA(I am going to install a Rockwell 4.11 on air ride in its place).I have a 16ft insulated body with low side entry door,that I am planning on using.Thanks again for the tips & reports!
#38
Yes that is the plan to paint the door and the exposed aluminum. the door was installed and steps made the week before i left on the trip. that is whay its not painted.
Product Categories | Welcome to Buyers Products Company
You can by these at the local truck parts dealer such as Fleetpride.
#39
#41
Re frame 1955 big job
Your toy hauler look neat keep up the good work.I'm looking to put a medium duty ford truck frame with a Cummings diesel under my f-750 big job body.Can you give me your front end measurements from the outside of your front wheels so i can see if it will fit under my wheel wells.Your help will be appreciated keep on trucking.
#42
Mine has 275/75R22.5 Firestone 560 tires,air brakes and a 10K front axle.
The lug nuts and center of the wheel sits out side the fenders edge.
I am thinking some of the lighter duty F600s-and F-700s might be narrower.
#43
The air ride axle is now going to be my winter project.
Now I have A/c in the living quarters. I mounted a portable AC unit to the wall and piped the hot air though the wall with (2) 4 inch dryer outlets.
I also applied Sound deadner to the inner sides of the door skins inner sides of the door panels, inner back side of the cab sheet steel.
What is used is HVAC Duct sealant. $20 a gallon and I swear I think it is the same stuff as lizard skin which is $150-$160 per gallon.
This truck is MUCH quieter now.
#45
