Odd THUMP coming from the rear after applying brakes
Ok fellars, I usually don't bug everyone with my truck issues, but this one really has me stumped....
The truck:
1992
F150
2wd
longbed
It does have the Rear ABS.....
I have acquired a THUMP when I apply the brakes, you stomp the brakes, the rear wheels lock up (A no-no, since it is a RABS truck) and it sounds and feels like someone hit the rearend with a sledgehammer....Softly depress the pedal, it sounds like a gentle TAP.....W-T-F?
The brake pedal is very solid, not spongy feeling, the front brakes are new, and the rear brake drums were replaced yesterday....It seems to have softened the THUMP, but it is still there....
I have new rear brake shoes, and spring kits to put on the rear....Then the only thing left to replace is just the Wheel Cylinders...
So what does it sound like to you guys?
Thanks in advance-
-Wes
P.S-The mechanic that helped me put the rear shackles on adjusted the shoes to fit the new drums, and that also seemed to help.....The old P/S drum had a fleeck broken off the outer rim of the drum, it was a place roughly 2" x 1/4".......Just noted that in there to possibly help diagnose this issue....And btw, the broken area looked REALLY old....
The truck:
1992
F150
2wd
longbed
Thanks in advance-
-Wes
I HATE REAR DRUMS with a passion!
IMHO... Return all the drum breaks parts you just bought...
Convert to rear disks and never look back! If I could have done it all over again I would have done the same. Drum breaks are a PITA!!!!!!!!!!!!!!!!!!! Ford Sterling Disc Brake Bracket, '84-'94 [Sterling] - $50.00 , Reviews
F-250 WARHORSE
24
01-26-2017 09:05 PM
tuxedobuttonquail
09-23-2016 03:40 PM
rgnprof
15
07-13-2016 07:26 PM
Shadow351
1997 - 2003 F150
03-15-2016 05:55 PM
dpbrowne
01-21-2005 03:54 PM
