Diesel Leak
Old 05-07-2014, 09:21 PM
PhotogSam's Avatar
PhotogSam
PhotogSam is offline
Diesel Leak
Hey guys, I have had a diesel leak for quite some time, and have just recently identified where it is coming from, but need to know what it is.
Any info would be of great value to me to know what this part is, and why it might be leaking, and of course lastly the best way to resolve the issue. As I just put a new SouthBend clutch in and don't want diesel dripping down into the bell housing and getting onto my new very expensive clutch.
So as you can see from the picture below it is on the right side of the fuel bowl, the part that is leaking is circled in green and then the 7 dots indicate where it is leaking from. It is a pretty stead stream of diesel that is coming out when the truck is running.
Thanks for any help you guys can offer.
Sam
Old 05-07-2014, 09:28 PM
T_F_E's Avatar
T_F_E
T_F_E is offline
its a 1/8 npt pipe plug
Old 05-07-2014, 09:36 PM
PhotogSam's Avatar
PhotogSam
Thanks for the reply Mike, so am I safe to assume that I can just remove that and replace it with another solid plug?
Old 05-07-2014, 11:35 PM
DarkStarMedia's Avatar
DarkStarMedia
DarkStarMedia is offline
That is the water in fuel sensor. Try sticking a wrench on it and tightening it a bit. OOr you can remove and plug it...
Richard
Old 05-08-2014, 02:42 AM
Tyler.172's Avatar
Tyler.172
Tyler.172 is offline
Or you can take it out put Teflon tape on the threads and reinstall it to give it a better seal
Old 05-08-2014, 05:33 AM
91 Dually's Avatar
91 Dually
91 Dually is offline
Whatever you decide to do,
Be very careful not to over toghten that. The fpr is pot metal, and will split at those threads if overtightened. Ummm, dont ask me how I know this. lol
Old 05-08-2014, 09:06 AM
farmert's Avatar
farmert
farmert is offline
Richard
That is the fuel filter restriction sensor, not WIF. It can be removed and a pipe plug used as stated. Myself I like to have the sensor in there to help see what is going on with the fuel system.
Old 05-09-2014, 03:20 PM
mapachoo's Avatar
mapachoo
mapachoo is offline
4wd Low
diesel o-rings at
Navistar Fuel Bowl Filter Restriction Sensor
$30.78 plus get a tube of Gasoila thread sealer 1 tube about $10.00 will last you a lifetime superior to Teflon Tape as its made for sealing petroleum parts Bob has it in stock as well
Old 05-09-2014, 03:30 PM
DarkStarMedia
I stand corrected.
richard
Resendiz
20
10-16-2016 05:07 PM
cgolden9
01-03-2015 04:24 PM
lawaia21
06-14-2011 02:44 PM
MrCBofBCinTX
08-26-2010 12:34 PM
MrCBofBCinTX
05-30-2004 12:26 PM
Quick Reply: Diesel Leak
