HOLY S!%T Scared Lost all Throttle almost is a Wreck
When driving exiting the highway I lost all throttle a few weeks back. I put it in Neutral turned off and refired while coasting and everything was fine. It seems to be getting worse, while driving I lose my pedal and it comes back after 10 second or so.
Any ideas?
DO I need to replace the throttle pedal assembly?
How long does it take to replace?
Any Check Engine lights? all gauges still work when this happenst? Any mods to your truck and what year is it? Sorry for all the questions, but the more we know, the better our guess will be.
bad pedal assm. mines done it twice now. some folks have had luck cleaning out the switch with contact cleaner. I've had to replace the pedal. it gets real exciting when you're pulling a long grade with a 18K 5th wheel and go for a down shift and the pedal dies! slap it up and down with foot and it will come back and then die again at the least opportune moment!
