Painting an ATS turbo housing ?
I put an ATS turbo housing on last fall, and it works great. It looks like Barney's ear, though, and I was thinking of painting when I clean up some stuff during an up-pipe install. Can I just rough it up and paint it, or do I need to remove all that awful purple?
Sorry this isn't the most technical of questions, but painting stuff isn't exactly a strength of mine.
Mark
Mark
If its powdercoat you'll have a he'll of a time getting that stuff off. And if it is pc just rough it up and paint over it, and if it's paint see if you can get it bead blasted. Out shop powdercoats as well as a fab shop so I know how tuff that stuff can be to get off, normally we have to burn it off and on alum that can get tricky! Lol speaking from costly experiences!
If it is powder coat you should be able to easily remove it with Aircraft paint stripper. This can be found at any auto parts store. Paint it on...let it sit and bubble up...scrape of the powder coat. Paint or re-powder coat your color of choice. I did it to several Mustang intakes and it worked great.
I painted exhaust manifolds with this stuff and its holding up fine...
I don't think a turbo ever sees the temps that headers do. Not on our trucks at least. Also I have used the VHT flat on my last car that had a big turbo upgrade and the paint looked as good as the day I sprayed it when I took it off and parted the car out.
What do you think the purple is? Is it just just bare aluminum that has tarnished from the heat? If so just scuff it up / clean it w/ steel wool and follow the directions on the can.
Kornnut
11-21-2015 06:42 PM
paddlefish
01-18-2001 08:06 PM
