drivers side oil leak
My truck now decided it likes to leak oil all over the place. I figured it was the oil cooler because i keep hearing about that problem. However. I cant catch it leaking there. The frame rail is wet. the steering column shaft is wet. the bottom of the exhaust manifold is wet, the front axle, drive shaft, and leaf spring is wet. everything is soaked but if i clean it up and leave it running i cant see it dripping. seems to be when I am driving it only????
top of the motor is dry, valve covers are dry, the valley of death is dry. I am thinking I am going to go for the cooler and pull it apart but I wanted to ask u guys what u think?
Just an update...
I pulled the plug out of the head last night.. it seemed dry but I pulled it anyway. new ring, back together, Still leaking. It seems to be only when its hot. I started and let it run with clean cardboard under it for 20 minutes. No drops... then I drove it for about a half hour pulled in the garage, shut it off, and drip..drip..drip.. all wet. frame rail, spring, front axle, soaked all on the drivers side. Oil was dripping off the oil filter but i took it off and it looked like it was sealed and tight. Think I am going to go after the cooler next???
I think I am going to get some gunk, and hit the car wash and clean it up, try to see where it gets wet first.
Still open to suggestions?
