Programmer questions (split/merged posts BA)
Old 05-23-2004, 09:18 AM
txc35's Avatar
txc35
txc35 is offline
Hey sriggle, saw your post up above and wanted to know what a programmer is? I have an '01 and get abotu 21-22 on teh highway with an KnN filter andthis caught my eye. thanks for the help.
Tom
Old 05-24-2004, 06:28 PM
sigma's Avatar
sigma
sigma is offline
SCT extreme flash microprogramer gives you full user access to 30 key functions including timing and fuel management. Programming actually takes place on your PC and is uploaded to the programmer then you simply plug the unit into your OBD port and flash the computer just like the dealer would. It’s pretty cool. Mine cost me $450, but it’s really worth it.
Old 05-24-2004, 06:59 PM
txc35's Avatar
txc35
txc35 is offline
Sigma, thanks for the reply. Sounds interesting. Where would I get one of these...from the Ford dealership? I would like to find out more about what these can actually do. Thanks.
Tom
Old 05-25-2004, 05:46 AM
sigma's Avatar
sigma
sigma is offline
The sponsor of this board http://www.motorhaven.com sells Superchips. While the tuner for the 4.2 is not listed, Ken could probably get one for you. If he does not sell this model, let me know and I’ll pass on another contact.
You can read about the tuner here http://www.superchipscustom.com/truck_page.php
Old 05-25-2004, 08:04 AM
txc35's Avatar
txc35
txc35 is offline
Thanks for the response Sigma. I checked out the web sites you listed and it looks like I can get a diablo chip from Motor Haven. Do I also need the tuner? It sounds like these are 2 different products and I will need both, is that correct? Would I be wise to shop around for different chips from ifferent manufacturers who may have varying levels of quality? Wat brand do you use and are you satisfied with the power difference and mileage change? What would you recommend? Sorry for alll of the questions; new to this game and trying to learn/figure things out. Thanks for all your help.
Tom
Old 05-25-2004, 10:35 AM
sigma's Avatar
sigma
sigma is offline
No you need a chip or a tuner you do not need both.
Old 05-26-2004, 01:25 PM
wezard's Avatar
wezard
wezard is offline
Don't shop, just get Diablo. If you want a tuner, wait for the new diablo to come out.
A chip is install and forget, if you get a multi stage there is a little switch that you mount on or under the dash. When you want to change the program, just flip the switch.
Mine has 2 stages plus stock, for 3 switch positions. About $230.00. It works as advertised and I'm real happy.
A tuner will come with a couple of programs built in. To use it you connect to the OBD port and re-flash the trucks computor, takes a couple of minutes. Most tuners also double as a code reader, and you can adjust all kinds of settings on your truck.
If you really know what you are doing, the tuner is much more versitale, and by doubling as a code reader will offset some of the added cost.
Go over to the chips forum and surf around some.
Mike
Old 03-07-2011, 05:05 AM
ifitrocks's Avatar
ifitrocks
ifitrocks is offline
anyone had any experience with a jet programmer? i have a 1996 f250 5.8L
tip49
06-07-2013 02:18 PM
Tom D
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
03-25-2008 07:29 AM
glruff
New Jersey Chapter
148
12-13-2007 09:13 AM
bunnycop
Computer Chips & Tuners
08-24-2005 03:58 PM
Quick Reply: Programmer questions (split/merged posts BA)
