Interesting question. 6.2L versus the Ecoboost and 5.0L
#46
Off-topic: from the news and from the Japanese traders I've talked to the big issue is restoring the Fukushima Plant’s core coolant recirculation after the coolant lines were damaged as a result of the quake.
This effects us as well as the west coast can expect fallout some 36 hours after a core melt down should the core heat up enough to melt through its containment.
#47
Will let you know soon enough when I get my 6.2L regarding the towing and gas mileage.
By the way, I finally test drove the beast 6.2L and can easily say that it is by far the most powerful engine I have ever driven. Incredible/insane power...I recommend all to go and try one out...and then let's talk truck...
#48
I wish the 6.2 was an option in the truck I ordered. But because i wanted a 6.5' bed supercrew it was not. with that said I am not sure I would have gone the 6.2 over the ecoboost. I choose the EcoBoost because of its low rpm torque numbers And hope of better non towing mpg's. I just can't see the 6.2 getting the same non towing mpg's. Before I ordered my f150 I was going to order a F250 SD. to pull my travel trailer. After doing some hard research and really evaluating how I would use my truck. I decided the F150 with ecoboost would better serve my needs. For pure towing the F150 and sd's are not even in the same league. I will be pulling my travel trailer on 4 or 5 short trips per year. The rest of the time will be just a fishing and hunting truck. Something any f150 can handle with ease.
#49
@DRH, the EcoBoost could use twice as much fuel as the 6.2 while towing (which it doesn't), and you'd still be better off. My needs are the same, pull a camper maybe a couple of times a year. Though I'd like to go more often. I need something that will do it, but not every day. It will be nice to know the fuel economy is also better while towing, but it doesn't matter if it does not.
#50
#51
As I mentioned last night, there's a huge difference between the 6.7 & EB on just about every level, but on paper at least, the EB seems to hit the sweet spot of great towing capability & general all around fuel economy. That being said, my decision is not yet made. I'm hoping to see some 150 & SD info surface soon about what might be happening for the '12 MY.
#52
6.2L is crap I bought my truck new with the 6.2L it is sluggish if you are going to buy a truck do not buy a v6 model, it is my first brand new vehicle and the most disappointing ford product I have ever owned, not even 2yrs old and already leaking oil from gaskets. GRRRR!!! Trade you my v6 for you're gas guzzling v8 any day.
#53
#54
I didn't even look in the "little truck forum" four years ago.
Will say I like my 5.0 which although rated to tow about the same as my 2003 v-10 F350 crew cab, I know they would be different experiences.
Looking at original post....I might have took a 6.2 if they were around in the trim I wanted...but I wasn't even considering a v-6 and they were available more than the 5.0. Just wanted a v8 and couldn't care otherwise.
#55
#56
#58
It's that "Similar Thread" window below. Ever since they started putting that there, ancient threads have been dug up and commented on way more than in the past. I was looking up some stuff last week and there was a "similar thread" in that window from 2005. It should be titled "Useless Ancient Threads".
