Why 2 turbos?
Adding another turbo is not adding boost. It is allowing a smaller turbo to be used that takes less time to spool up (lag).
Boost pressure is either dumped or recirculated when the throttle is closed while the engine is under boost. Boost pressure is regulated by the wastegate that bypasses exhaust gas around the turbine wheel so that it does not keep increasing turbine speed and exhaust pressure.
F-250 WARHORSE
10-07-2016 09:41 AM
Markiv
03-10-2014 10:55 PM
