RiffRaff Orange intake boot Pictures and comparison
Thank you Sir . Props to Clay, that's a RiffRaff'ed intake
Just a head up on the SD boot (that you may already know...) It will not bolt up to the original piece that the CCV goes into, the SD boot diameter is a bit bigger. I used a 4" (IIRC??) piece of exhaust scrap and used that.
Just a head up on the SD boot (that you may already know...) It will not bolt up to the original piece that the CCV goes into, the SD boot diameter is a bit bigger. I used a 4" (IIRC??) piece of exhaust scrap and used that. I went back to having the CCV in the intake because I hated the smell and everyone thought there was something wrong with my truck with little puffs of smoke from under the front...
So the only other boot that bolt on is that from intakehoses.com, till I know.
Sous
108
06-06-2018 07:57 AM
ExPACamper
83
05-08-2017 05:30 PM
rat49f6
09-09-2010 04:30 PM
