WIPERS HALF WAY RIGHT
I was hoping someone has a cure for this. As you see in the first pic. Thats as far as it go's up and pic. # 2 is as far as it go's down but when you turn it on it will go further down Then start up. In these pics. the passenger side isn't installed but it was put on later and it seems to be ok. Is there some way to adjust them from under the dash. Cause thats as good as it gets from any adjustment you can do on the outside. Bought it from Classic Haulers .I called them today but nobody was home.
electric
they are electric ken and i'm sure i will get caught in the rain tom. Its almost summer showers time here in florida.When you live 30 miles off the coast it gets hot in the day then about 2 pm it pulls the cool air in from the gulf and BAM you got a lighten storm. Florida has more lighten stricks then any were on earth. Thats what i read anyway. Has anyone that put these electric wiper in there truck had this too deal with or am i just the lucky first?
Not hijacking the thread just making a comment
I lived in West Palm beach for two winters...and i loved that at about 2-3 it would cloud up, rain like the dickens and then clear up an hour later. I was working with horses at the time so it was a great way to cool off for a bit...Ahh i miss those days!
Sorry i don't have anything of use to say about your wipers. Have never had a problem with mine so its something i haven't taken apart yet. Hope you get it resolved soon...Florida rain is nothing to mess with. Only place i have been that i had wished my wipers would go faster than the highest setting!
Here's the pic from Classic Haulers;
I don't see any obvious adjustments anywhere. From the looks of it there's not much you can do. I can't tell how the linkage hooks up to the motor in this pic, was there any kind of adjustment there, all the other points are fixed. If there is a way to make the linkage longer at the motor I think it would translate into a broader sweep of the wipers...I think
Bobby
Bobby
I had a wiper assemble in my 50 that I bought back in the mid 90”s that looks the same as the one pictured. It looks like they are made by the same manufacture. In fact your picture shows pretty much how mine worked. The driver side was always an issue to me. The sweep was short on the top side and it parked in a high position. The instruction that came with the unit told how to adjust the park by loosening the motor arm (which is splined) and moving it. But in doing so I found that the sweep also was affected, so I left it as is because I mostly use the truck on nice days. On this rebuild I am installing air conditioning and the wiper assembly was in the way, so I replaced it with a unit from Rain Gear for a 50 with the cowl vent which tucks up high and left of where the original motor was. A little pricey, but a stout unit and well worth the money. I had a little problem fitting it in and called them and they responded right away. In fact they came to my house (it is made just an hour north of me) and made the adjustments. It sure opens up that area now. I hope this helps. Mike
