2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
HELP! No Driver Lowbeam! 07 expy
Old 02-27-2011, 11:50 PM
freerider's Avatar
freerider
freerider is offline
Cool HELP! No Driver Lowbeam! 07 expy
Driver side lowbeam has no power running to it on '07 expy.
I checked and replaced fuses for both passenger and driver lowbeams. The highbeams work for both sides!
And Ideas?
Old 02-28-2011, 09:17 AM
thomabb's Avatar
thomabb
thomabb is offline
Do you have power to the fuse?
Old 02-28-2011, 11:08 AM
kennisonxgs's Avatar
kennisonxgs
kennisonxgs is offline
Replace the driver side bulb. Likely the low beam filament is burnt.
Old 02-28-2011, 01:07 PM
freerider's Avatar
freerider
Forgot to mention that I replaced the bulb with 2 others...it was how I determined that there was no power to the low beam...
Someone mentioned that I should check the SBJ (subjunction box?) for power, but I have no idea where that is...
Old 02-28-2011, 01:34 PM
kennisonxgs
Maybe the bulb connector?
Old 03-07-2011, 07:40 AM
rmr319's Avatar
rmr319
rmr319 is offline
Had the same problem before when i replaced mine with HIDs. took my truck to the dealer and they said my headlight switch is the problem. they replaced it and now it works
