question for bill aka number dummy or .....
Old 03-05-2011, 07:54 AM
55 f350's Avatar
55 f350
55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
one of you versed in ford oe wheels . i'm trying to figure out if i'm gonna be able to put the 8.8 i have { i'm pretty sure it measured out at 55 or lil' over inches between the backing plates all i can find says 62 inch wheel track for the vic so ....} from that 88 vic . well i got to measuring my rims for offset , and all i can find is that ford steel rims are 15 by 6 . i got 3" from the center of the rim out to the front , and 4 inches from the center to the back of the rim . now if i'm not asleep at the wheel here that would make it what a 15 x 7 with 4 inches of offset ????????????? did ford have rims this width in 83 which is the year of the truck that donated them , and they have ford stamped in them . they have 235 's on them and they aren't pinched in or anything , actually the side walls are "puffed out " a little bit ........ so did they make these and what year ????
Old 03-05-2011, 09:24 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
Kevin - I'm not Bill, but might have an answer for you. Sounds like you are measuring from the outside rim lip to outside rim lip , am I right? Wheel width is, however, measured inside across the rim base. That would mean there's probably 1/2" additional distance on each side when you measure lip to lip. What you've done would be the correct method for measuring "back spacing", i.e. 4" back space. And what you've said would yield 1" of "positive offset". Here's a chart that might help.
Edit - To answer the rest of your question, an '83 F-150 could have had a 15" x 6" or a 15" x 8", plus a 16" and a 16.5". Likely yours are the 15" x 6". Stu
Old 03-05-2011, 03:10 PM
55 f350's Avatar
55 f350
55 f350 is offline
thanx stu i figured bill or you would answer . yes you are rught about the lip . went back out and remeasured and it is 6 inch . thanx stu !!!!!!!!!!!!!!!
mudduck2274
11-26-2012 08:55 PM
axbreck
11-02-2010 03:10 PM
Papadawg
02-17-2010 04:47 PM
four8fordf1
11-11-2008 04:20 PM
preppypyro
05-05-2006 09:50 PM
Quick Reply: question for bill aka number dummy or .....
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
