Is a tailgate seal any use? - Ford Truck Enthusiasts Forums
Old 03-03-2011, 01:26 AM
dcciie251
dcciie251 is offline
dcciie251 is starting off with a positive reputation.
I've noticed that many Internet stores sell these with a "free" tailgate seal. Obviously this is to keep water out, but is it necessary to get one of these when adding a bed cover? Do they work? Does a lot of water really come up through the tailgate when the bed is covered? I really don't want this, unless there is some compelling reason for it. Thanks.
Old 03-03-2011, 03:50 AM
svt2205
svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
It depends on what you are going to do with the bed of the truck. If it only carries boxes or other contained items. Then it might work just fine. But if you haul stone, mulch or other heavy items that may way down the seal and damage it. Then I would suggest you do what I did. Give the seal away.
Old 03-03-2011, 04:45 AM
fonefiddy
fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
It also seals out dust. Some peeps have pretty fancy toppers, carpeted beds, etc.
Old 03-03-2011, 05:45 AM
n5926g's Avatar
n5926g
n5926g is offline
n5926g is starting off with a positive reputation.
As stated earlier,it mostly seals out dust/dirt.I have a Tri-Fold cover,and bedliner on my 07 long box.Im normally maticulos about keeping the bed clean.I have no tailgate seal,and do see some small amounts of grunge near the rear from time to time.
Old 03-03-2011, 07:28 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I have a tailgate seal on my '06 with my roll up tonneau. It does a good job of keeping dust, mist from wet roads, and other road grime from getting into the bed. The bed on my truck serves as a "trunk" when the wife and I travel so it was necessary for me to make sure that her bags and clothes don't get covered in potentially harmful substances. For the $30 I paid for it, it suites me just fine.
EDIT: I did notice that the tailgate closes a little more firmly with the seal, than without. Since it's a tighter fit I also feel like the tailgate doesn't rattle, etc.
Old 03-10-2011, 05:16 PM
TrapperDave's Avatar
TrapperDave
TrapperDave is offline
TrapperDave is starting off with a positive reputation.
Good Post! I was wondering about the tail gate seal. I have a rugged tonneau cover and bed liner so I use my bed more as a trunk. But I also had another 2010 SCAB owner tell me that there are a few sheet metal areas on the bed which could also be silicon to keep out dust and dirt. He also said I should pull the bed mate twice a year and clean out the collection of dirt.
Old 03-10-2011, 06:24 PM
msgtord's Avatar
msgtord
msgtord is offline
msgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to all
I think you'll be surprised at the number of holes in the bed of your truck. I drive a dusty driveway, and put a seal on mine. But if you look to the front of the bed, you'll find more holes that need to be sealed as well.
Old 03-10-2011, 07:10 PM
fonefiddy
You NEED those holes in the bed front. They are the drain holes!
Old 03-10-2011, 10:59 PM
snowdog79's Avatar
snowdog79
snowdog79 is offline
snowdog79 is gaining momentum as a positive member of FTE.
Not if you have a cover and have sealed everything up... But you'd better not let any water in there or you'll have a portable swimming pool riding around with you.
Old 03-11-2011, 07:40 AM
kpendlet
kpendlet is offline
kpendlet is starting off with a positive reputation.
I've wondered about the seals also. Does the seal interfere with using the bed - for example, shoveling out a load of dirt/mulch/whatever, will a shovel snag on the seal, or is it installed clear of the inside of the bed?
Old 03-11-2011, 10:23 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
Here are pictures of mine. I'll let you determine for yourself. IMO you'd have to get the shovel pretty much wedged in the gap between the gate and the bed to damage the seal. I've had plenty of yard debris in the bed, but no loose gravel at this point (all my gravel was bagged) so I cannot speak to that extent.
Pics:
Texmudder
2017+ Super Duty
33
04-23-2018 08:45 AM
~erik~
2017+ Super Duty
08-09-2017 03:58 PM
Glenn54
15
07-19-2017 07:20 PM
superdave1
1978 - 1996 Big Bronco
04-04-2017 02:54 PM
d445
2009 - 2014 F150
27
02-03-2010 10:30 AM
Quick Reply: Is a tailgate seal any use?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
