machine shop questions?
Old Mar 13, 2003 | 10:16 PM
RUFUS79's Avatar
RUFUS79
hi guys just wondering when I take my 460 in to get bored and checked what should I have them do to it? I am new to the machining process and wanted to get more aquainted with it . What should I have done to it, and what dou you think it would cost? Just trying to learn more about it before I take it in..
Old Mar 14, 2003 | 12:32 AM
erikl85's Avatar
erikl85
Hmmm... My block is getting hot tanked, bored,magnafluxed, all the bearings are getting put in and the pistons are being put on the rods and it will cost around 130 bucks.
Old Mar 14, 2003 | 09:07 AM
RUFUS79's Avatar
RUFUS79
WOW is that all ? I thought I would pay close to at least 500 bucks for all that stuff. thanx
Old Mar 14, 2003 | 09:21 AM
georgedavila's Avatar
georgedavila
erik185 - that doesn't include boring, cylinder wall honing or balancing?
Old Mar 14, 2003 | 09:59 AM
erikl85's Avatar
erikl85
That is with boring and honing yes. But I have not gotten it balanced yet. They said that would cost another 100 bucks.
Old Mar 14, 2003 | 11:42 AM
georgedavila
That's really cheap. Prices here are:
Bore - 95
Deck and linebore mains - 153
Hang pistons on rods - 57
Cam bearings - 35
Balance - 175
Bake and clean block - 45
From other forums, the above prices are pretty standard. You really got a deal.
Old Mar 14, 2003 | 12:44 PM
Just Strokin's Avatar
Just Strokin
I just got a 3 angle valve job, new teflon seals and my intake bead blasted for $130 at the small local machine shop I use in Alabama. BTW, the seats for the valves were cut with a cutter, not ground with a stone.
Old Mar 14, 2003 | 03:39 PM
classic79's Avatar
classic79
Rufus-
have the block magnafluxed for cracks first, most will do that anyhow but double check.
then bore, hone, see if they use a torque plate during honing. Have the shop check and see if you need to have the blocked decked, or align honed as well.
I had my mustang engine, hot tanked, cleaned, magnafluxed, honed (torque plate),decked to ensure smooth surface for heads, honed, cam bearings installed (cheaper than buying the install tools yourself) pistons pressed on rods, rods resized, and the rotating assembly balanced. The balancing is the most costly part simply because of the time and labor involved and is not neccessary for a stock or mild buildup. My bill was about 600 for parts and labor.
Old Mar 14, 2003 | 04:04 PM
RUFUS79's Avatar
RUFUS79
thanx for all the input. it's going to go into a 79 f-250 np435 married np205 with maybe a 2 inch lift. Not yet decided but when she's together my chevy friends will see my taillights alot
