Fan Belt 1966 F250 352 alternatives
The V Belts on this 352 pull only the water pump and alternator (no air, PS and no air pump).
My 64-72 Master Parts Catalog shows that the JB446 belt is the correct belt for this application and that it measures 44.6 inches around the outside.
However that leaves very little room for adjustment as the alternator bracket is almost fully extended at this measurement.
I placed the alternator in the middle of the adjustment slot, cut one of the old belts, pulled it around the pulleys tight, marked the overlap and it measured 43 inches.
As long as I purchase two belts that are 15/32 wide on top, is there any reason I cannot find and use belts that are near to 43 inches? (like a JB423)
Thanks!!
Thanks!!
Patmedic, I am not sure why the stock belt length is almost too long. My Dad owned this truck since it was new and I know that the alternator was replaced a couple of times as well as the water pump. I suppose that it is possible that one of those pulleys is slightly smaller since they were aftermarket parts...but I admit that seems unlikely.
It makes me wonder if someone else with this 352 without air, air pump and power steering have a similar problem?? Perhaps someone will tell me.
Thanks for your advice!
Eddiec1564
10-13-2023 07:20 AM
scottperkins
1997 - 2003 F150
09-08-2015 05:10 PM
410 Highboy
02-12-2010 02:01 PM
