Pre turbo pyro site.
Old 02-28-2011, 10:01 AM
trekbasso's Avatar
trekbasso
trekbasso is offline
Hi all, I know some have a preference to the manifold, but, I am doing up pipes. I will have a new exhaust inlet manifold in my hands tonight (two broken bolts, one broken "easy out", not enough PJ Blaster in the world).
Is there any reason not to drill and tap the manifold?
It is just too easy for me to do, and most of the how to articles assume everything is still bolted up.
I will plug hole for now, gauges can't happen for a couple of more weeks.
Thanks in advance.
Tom.
Old 02-28-2011, 10:06 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
It works in either way. I'm a little confused with your terminology though. It usually goes in the driver's side exhaust manifold or the up-pipe. The collector at the turbo inlet has nothing to do with it. Here's where mine is:
Old 02-28-2011, 10:07 AM
Bird Dog's Avatar
Bird Dog
Bird Dog is offline
Mine is in the up pipe about 2" from where it connects to the manifold. Same place as Joes above.
Old 02-28-2011, 10:14 AM
trekbasso's Avatar
trekbasso
Thanks and good pic izzy. I will have to plug the hole for now, and not sure how well I can do that on the pipe itself. My reasoning is just easier to drill somewhere now with it all apart, and no worries about access or shavings, hence the thought of drilling the manifold part.
What helps the sender stay in the pipe? I wouldn't think there is much metal to thread?
Old 02-28-2011, 10:23 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
There's plenty of metal in the up-pipe to tap. Mine has been there 4 years. If you do tap the up-pipe, don't run the tap all the way in. Once you get it in about 1/2 way, start trial fitting the adapter or plug.
And as far as the shavings, don't worry about it. Most of them fall out -- whatever is in will just blow out the turbo. All I did was drill, tap, install adapter & sensor, and start the truck. No worries...
Old 02-28-2011, 10:26 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
Got mine in the drivers manifold, but like the other guys mentioned, the up pipe is a fine location too!
Old 02-28-2011, 10:50 AM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
i would stick it in the manifold. that way when you mess with your uppies again you wont have to fool around with the pyro thermocouple......
Old 02-28-2011, 11:17 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Mine is in the manifold too. Quick question, would it make sence to run 2 egt gauges one on each side to see if one side is running hot or cold? Thanks and sorry for the temp. hijack
Old 02-28-2011, 11:24 AM
trekbasso's Avatar
trekbasso
It's cool. Good question. I can't afford one right now but would if I could.
Tom.
Old 02-28-2011, 12:20 PM
woodnthings
There are a few guys running dual EGT gauges and probes. It would be kind of cool to see the difference, but in reality they should be really close as long as everything is working well.
Old 02-28-2011, 02:02 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
That would be my point exactly, sometimes somethings going on that you dont know and dual gauges would help out, thanks for the response,
sunsettractor
21
08-19-2013 03:10 PM
BrownBrutus
17
01-31-2013 10:18 AM
topwhop
2004 - 2008 F150
05-29-2008 05:32 AM
marcussen
04-20-2007 10:39 PM
tdg351w
43
02-20-2005 12:47 AM
Quick Reply: Pre turbo pyro site.
