Anybody ever had the romps at 74*F?
Wow! I was under the impression the fuel needed to be around 130 or so. Maybe that's when it burns it's best?
As long as the grease is clean it runs great.
I'm giving you guys the secrect to saving $$$$ right here
Cool. Curious to see if your symptoms return.
Oh yeah, to answer your original question...the only time my truck has ever had the romps was about 70 degrees at 7500 ft altitude. Started fine in colder temps at lower elevations but sure was cold blooded at high altitude until I replaced the glow plugs.
Do your parents live at high altitude?
Define high altitude. Its all relative i guess. Down in south La., the slab of parents house sits at about 8ft above sea level. But after a few hurricanes with some flooding you gotta do what you gotta do (this is the only pic i had easily available, this was the beginning of the lift of the house up to 12ft above the slab.) Where I come from, thats living at "high altitude".
Everything started and ran fine today. Hopefully it was just a fluke thing. Its sure to raise its head again as it gets on in age.
I was thinking 6000 ft plus as high altitude myself. I've been through Louisiana once or twice and I don't remember seeing any mountains but then again I didn't venture too far inland.
I thought it to be super strange that my truck would have such a hard time starting in the middle of the Arizona summer in the high country but never gave me any trouble during the winter down at lower elevations. I figure the PCM must use the baro value to meter the fuel for that to happen. As far as I know, there isn't a stand alone baro sensor anywhere so I imagine it must be integrated in the PCM but I'm not really too sure.
I have a lot to learn about the programming of these engines but I imagine that temp isn't the only factor that can cause the romps. To me, it seems like a timing related thing...
It does seem a bit outta place. House was builtin '80, flooded two weeks after moving in, flooded for Rita in 05, flooded for Ike in 08, about a foot higher than Rita. Mom said enough was enough. It was a cool project. Did as much of the work ourselves as we could. Started by stripping walls 4ft and down, the run 2x12's around entire inside of house at that level for beams to hold the weight, cut all anchors to the slab, lifted her up, set poles in ground underneath her, built floor under the house, lowered house down on floor and "reattached the house" lol. Started in Dec 08, moved back in June 09. Now is fully equipped with a home built elevator to boot.
