97 f250 4x4 heavy duty
Old 02-27-2011, 11:21 AM
footn
footn is offline
footn is starting off with a positive reputation.
i just bought a 97 f250 ex cab long box 4x4 heavy duty with the 7.5l does it have air bags? drivers or passanger side? i have my little girl and would like to know if i have to put her in the back! if it does can you shut them off? also the horn doesnt work, can i pull the steering wheel cover off? or is there an air bag in there?
Old 02-27-2011, 11:24 AM
topdogcustoms
topdogcustoms is offline
topdogcustoms is starting off with a positive reputation.
driver side air bag only and the air bag is under the wheel cover but you can still pull it off
Old 02-27-2011, 11:34 AM
96f350az's Avatar
96f350az
96f350az is offline
96f350az is gaining momentum as a positive member of FTE.96f350az is gaining momentum as a positive member of FTE.
i dont have airbags.. not that i know of. hmmmmm
Old 02-27-2011, 11:44 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
NO. NO AIR BAGS. F250 and larger did not get air bags till 99
Old 02-27-2011, 12:29 PM
footn
footn is offline
well i didnt think there was one on the passenger side but thanks topdogcustoms, there is one on the steering wheel. there is a airdag indicator light on the dash, so now i know where it is!
Old 02-27-2011, 12:43 PM
96f350az's Avatar
96f350az
96f350az is offline
i have the same airbag guy on the clustere. but im pretty sure i dont have airbags.
Old 02-27-2011, 01:49 PM
rstrong's Avatar
rstrong
rstrong is offline
rstrong is starting off with a positive reputation.
MY 97 250, and my 95 350, both have the air bag light, but no air bags the light never comes on.
Old 02-27-2011, 02:23 PM
rikard's Avatar
rikard
rikard is offline
rikard is gaining momentum as a positive member of FTE.
The airbag steering wheel looks pretty different from the non airbag wheel with a larger squarer center pad. My 94 and 95 F150s had the driver's side airbag, my nephew's 97 F250 HD (old style) and 92 F150 had the same non airbag steering wheel. Passenger side airbags were only offered on the newer body styles. Do be careful about using the back seat with kids and the back glass. My Grandson loves the fact that he can ride in the front of my truck.
Please be careful and follow all safety instructions before removing the airbag pad.
regards
rikard
Old 02-27-2011, 03:00 PM
footn
footn is offline
Thanks for the info guys! ya i think it is the small square steering wheel, i'll see later when i go out. any info on pulling out the radio? i want to install my kenwood deck. is there a trick on getting it out?
Diesel_Brad
YOU HAVE NO AIR BAGS IN YOUR TRUCK. Only half tons had them up untill 99, then the F250 and larger got them too
Old 02-27-2011, 03:25 PM
footn
footn is offline
Thanx deisel brad, finally got it figured out, ya there isnt one, lol
do you know if there is a trick to pulling the radio out? so i can install a cd player!
Old 02-27-2011, 04:44 PM
jjsfrd's Avatar
jjsfrd
jjsfrd is offline
jjsfrd is starting off with a positive reputation.
Old 02-27-2011, 06:24 PM
footn
footn is offline
ya its just an am/fm radio, just a little different than the on in your pic, thanks the info is good.
nice truck you have, mine is whits too but an ex cab. what lift did you put in it and what tires you running? i want the same look!
Old 02-27-2011, 06:50 PM
Turx
Turx is offline
Turx is starting off with a positive reputation.
Easy job with the 2 "removal tools" for the 4 small holes, 1 in each corner of the stereo.
Old 02-27-2011, 09:31 PM
jjsfrd's Avatar
jjsfrd
jjsfrd is offline
4" superlift, super runner steering system, 35" BFG's.
J
jaytuck
1997 - 2003 F150
20
06-10-2016 05:21 PM
sadyedog1
1999 to 2016 Super Duty
07-11-2011 05:29 AM
ballfan95
1997 - 2003 F150
06-12-2011 04:43 PM
Indie_6
06-29-2010 06:43 AM
stx123
05-04-2006 08:43 PM
Quick Reply: 97 f250 4x4 heavy duty
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
