Anyone replaced balljoints on the front of a 92 F-150 4x4
Old 02-27-2011, 11:10 AM
wattd55
wattd55 is offline
wattd55 is starting off with a positive reputation.
I am trying to replace the top and bottom ball joints on my 4x4--When I try to remove the hub lock ring( it sits in a groove in the hub ), the lock ring moves and is being hard to get out. I need this out so I can remove the spindle and replace the ball joints as the right front is badly worn out. Is a special tool for this? In my Haynes manual it says to use a small screwdriver, which I tried for hours. Help
Old 02-27-2011, 01:09 PM
Lazy K
Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
https://www.ford-trucks.com/forums/9...-u-joints.html Here is a good writeup on replacing ball joints.
Now if you have something like a fine dental pick or a very fine screwdriver you should be able to get under the snap ring and pry it out, it can be a PITA.
Old 02-27-2011, 07:24 PM
wattd55
wattd55 is offline
ball joints
Thanks a bunch for the link--It has really good info--What is a PITA?
Old 02-27-2011, 08:19 PM
buck_'s Avatar
buck_
buck_ is offline
buck_ is starting off with a positive reputation.
Originally Posted by wattd55 View Post
What is a PITA?
Pain in the A__
Old 02-27-2011, 08:56 PM
wattd55
wattd55 is offline
PITA
Yes it is--This is the third Ford 4x4 I have owned and did not have this on the others--Thanks
Old 02-27-2011, 09:19 PM
fatboyf150's Avatar
fatboyf150
fatboyf150 is offline
fatboyf150 is starting off with a positive reputation.
while you are that deep into it, be sure to replace the the axle bearing and seals in the spindle.
fall4curt
1999 to 2016 Super Duty
05-31-2016 08:41 PM
Byoung Oh
03-13-2016 08:24 PM
BillyBob69
05-19-2015 10:17 AM
wy4525
05-08-2015 05:27 PM
ccoram
03-28-2008 03:16 AM
Quick Reply: Anyone replaced balljoints on the front of a 92 F-150 4x4
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
