1990 cab on 1986 frame?
Old 02-27-2011, 12:01 AM
88 F250 DIESEL
88 F250 DIESEL is offline
88 F250 DIESEL is starting off with a positive reputation.
Question 1990 cab on 1986 frame?
Will a 1990 cab, & 300 e.f.i. motor convert to an '86 frame? The '86 has 300 carb motor which is bad. Would moving the cab from the '90, with the 300 efi help with wiring issues on the '86 frame. I have heard you would have to transfer the gas tanks from the '90 to the 86 frame, is this true?
Old 02-27-2011, 06:58 AM
jejdavis's Avatar
jejdavis
jejdavis is offline
jejdavis is starting off with a positive reputation.
The cab will go on the frame yes and would help with the wiring problem. You do have to switch the tanks if the 86 is carb simply because you will need the electric fuel pump to run the efi motor.
Old 02-27-2011, 07:17 AM
cj06's Avatar
cj06
cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
you may just need to switch the sending units as the newer one contains the pump so check them when all is apart ! you will need to make sure that there is a return line for the EFI !
Old 02-27-2011, 07:19 AM
atccracing
atccracing is offline
atccracing is starting off with a positive reputation.
A lot of work, but very doable. Goodluck!
85lebaront2
705
07-29-2016 09:56 PM
-jb-
15
07-26-2016 03:53 PM
1990-f250
06-15-2014 11:59 AM
GLR
06-02-2014 07:19 AM
AMXchuck
07-12-2011 07:54 PM
Quick Reply: 1990 cab on 1986 frame?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
