Is this hole supposed to be here?
Old 02-26-2011, 08:23 PM
fdude64's Avatar
fdude64
fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
i found this hole in my frame today. is it supposed to be there? and how would you fix it? it is right behind the right front rear spring hanger, 95 f 350 4x4
Old 02-26-2011, 08:36 PM
GLR's Avatar
GLR
GLR is offline
Posting Legend
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
It's called rust. A good cleaning would help you spot any more holes and show the extent of the damage. The frame looks like it would be thin behind the spring mount. Any repairs should involve spring mount removal. While you're checking both sides, also look a rear spring shackle mount and rear upper shock mounts. You might be looking at a frame "transplant" In some states that would not pass dmv inspection.
Old 02-26-2011, 08:56 PM
fdude64's Avatar
fdude64
fdude64 is offline
well i am replacing both the right rear spring mounts already. and the left rear front spring mount. the rear of the frame looks better
Old 02-26-2011, 11:43 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Wow, I live deep in the rust belt, and never seen a hole clean through a frame like that!
Old 02-27-2011, 07:23 AM
fdude64's Avatar
fdude64
fdude64 is offline
i think the truck was parked in a field at some point. the guy i got it from said he got it from an old farmer.
Old 02-27-2011, 08:32 AM
fishforlife2007's Avatar
fishforlife2007
fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
clean it up and patch.
Old 02-27-2011, 08:51 AM
BLK94
BLK94 is offline
BLK94 is starting off with a positive reputation.
I would get rid of it. That's just me though.If you have one you might have others.
Old 02-27-2011, 09:16 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
I would be powerwashing the frame REALLY good and going over the entire thing with a fine tooth comb. Then reevaluate the entire truck, weather to try and fix or scrap.
I am sure if there is rot there(not a typical spot) the normal spots are going to be really bad
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
