Milemarker Hubs Question
Need to understand what part of the drivetrain stops turning when I shift the hubs from locked to unlocked.
Reason is that with dash 4WD selector off and hubs in locked position I get a vibration - something like an out of balance tire. When I switch the hubs to the unlocked position the vibration goes away. So, I'm trying to understand where my problem might be - out of balance front DS, front axle, etc. but I need to know what stops turning when I unlock the hubs.
Thanks...
Thanks...
When you keep the dash in 2wd and lock the hubs, the axle shaft, axle U-joints and hub now turn. Some good reading here:
https://www.ford-trucks.com/forums/69...auto-hubs.html
https://www.ford-trucks.com/forums/83...auto-mode.html
Vibration could come from those axle U joints. How do they look and feel when you jack the front tire off the ground? Tight? loose? fresh rust at the edge of the cap?
Link works and out of the 9 page post, its post #18 that give a pretty good description.
In answer to my own question - with the dash switch in 2wd and the manual hubs locked the wheels, front axles and front driveshaft all are turning and the transfer case is disengaged. With the dash switch in 2WD and manual hubs unlocked only the wheels are turning, front axles and front driveshaft are not.
So, my vibration could be due to front driveshaft out of balance, front axles bent, or U-joints.
Thanks for the help...
You can verify the problem when you pull the hub off. You will see damage to the axle stub shaft where the bearing rides.
Just one more thing to consider since the front axles are not known to bend unless your're rock crawling with your X. And the front drive shaft balance is not a common issue.
sowaxeman
10-23-2023 08:14 AM
f100guy
1999 to 2016 Super Duty
10-02-2016 12:30 PM
curioduo
08-06-2015 09:22 PM
