Axle pivot bushings
Old 02-26-2011, 10:19 AM
ScottM1991
ScottM1991 is offline
ScottM1991 is starting off with a positive reputation.
Axle pivot bushings
I have a 1991 F-150 2WD and I am trying to install polyurethane axle pivot bushings. I used a floor jack to raise the I beam into the bracket but can't get the holes to line up. Have tried with the radius arms attached and loose. The hole on one side of the bracket will line up and the bolt will go into the sleeve, but the other side of the bracket is off by 1/8 inch. The truck has a 3-4 inch lift. I have installed rubber bushings on a stock height truck with no problem. Are the bushings different on lift kits. I do not know the brand of the lift kit.
Old 02-26-2011, 10:39 AM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
I believe you have to file down the sleeve to get them in. I used a porta power on mine and opened up between the ears.
Old 02-27-2011, 06:58 PM
ScottM1991
Thanks for the reply. Couldn't find a Porta Power to rent so I used a piece of allthread, two nuts and washers. My brackets have holes that are lower than the ones I used. I put the allthread throhgh the holes with two nuts and washers between the ears and spread them that way. Thanks for the idea.
jdq1986
29
06-23-2014 09:26 PM
jimbo285
1978 - 1996 Big Bronco
05-18-2012 03:46 PM
USMC35thSS
03-10-2011 07:29 PM
arkredneck
40
01-02-2010 07:12 AM
redlight mike
Offroad & 4x4
13
12-26-2007 09:38 PM
Quick Reply: Axle pivot bushings
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
