F350 ignition rigged. How to fix?
^^^ What he says.
However it could be that the ign switch has moved adjustment on the steering column (bolted to column under the dash). You could check that and maybe try adjusting it.
It could also be that the gear teeth on the actuator (behind the key switch) are bad and not moving the rod that connects to the ign switch enough.
It could also be that the ign switch itself is bad, you could check that by moving it manually while trying the adjustment.
chewedtoothpick
1999 to 2016 Super Duty
04-23-2013 07:27 PM
Zephyrhills Ford
06-26-2010 01:19 PM
89foxGT
07-03-2009 02:42 PM
ahurt1973
10-25-2006 02:52 PM
eclectix
Electrical Systems/Wiring
07-27-2003 09:30 AM
