Navigator Steering Wheel Swap for Non-Redundant Control Ex's: How-to
#61
#62
I also just remembered I should update the Blackwood wheel thread too, so I did, and linked it at the top. Blackwood part aside, those instructions are very relevant for just a straight swap, for someone who wants a wood wheel. This thread is much more complicated, for specifically adding the radio and HVAC controls, regardless of wheel style.
#63
#64
Are you swapping a steering wheel with cruise control buttons only to one with cruise control, audio and climate control buttons? Or does your current wheel already have all the buttons and you are just upgrading to get the wood steering wheel?
#65
I haven't figured out the check engine light code yet. I've looked for any chafed wires and can't find any. When I turn the key to the on position without starting the engine this part clicks Non-Stop. Can someone help me identify this part? Is this part supposed to click prior to the engine? I will look into purchasing software in the future to read codes. I really appreciate all the help.
#66
I'm also not sure on your different color steering wheel wiring. I heard there could be some differences between the wheels. Are the plugs the same?
#67
#68
Okay so I got a new wheel with the correct wires and harness. I hooked it up and after some troublesshooting got the radio controls working great. I hadt to cut the green and orange wire and leave it unconnected for the radio module to work. I took the truck for a test drive and the cruise worked. However the second time I took the truck out the cruise would no longer work. When i test the ohms only some of the buttons register. However if I unplug the clock spring from the truck harness all the cruise buttons work. It's as if the truck harness is delivering power ir something and canceling out the cruise cintrols. Any suggestions?
#69
This afternoon I took the truck out and I couldn't get the front fan to work . Do you think that has something to do with this vacuum pump?
I only drove it for a couple minutes but the fan wouldn't work on either of the settings. However, the rear fan worked fine. =ford_model'a';17575755]Pastor that is your truck's vacuum pump. I assume you have a diesel. That pump will start up as soon as you turn the key to the run position and will run until the reservoir is empty unless you have a leak somewhere.[/QUOTE]
#70
Since you say front fan and rear fan I assume you mean the interior climate control front blower. The diverters that send air to the dash, floor, or defrost are controlled by vacuum and if you don't have any vacuum it always comes out of the defrost. If that is what is happening then it's probably a vacuum problem yes. If your vacuum pump is clicking instead of running, it should sound like a kind of loud little motor running, then yes that's the problem.
If the blower itself is not turning on at all and you have no airflow anywhere in the front, no that is something else.
#71
Thanks for the response. I have no airflow anywhere in the front. The fan dosen't turn on. I checked the fuse in the engine compartment and that looks fine. The rear HVAC blower works fine.
#72
Hello All
Just wanted to give a quick update. All controls are working now. It turned out to be a two bad controls on the steering wheel. All is good now. Also, the problem with the fan turned out to be the fuse. I wasn't aware that the fuse for the fan is the same as the air bag. I thought that was strange. Anyhow, all is good. Thanks
#73
Hello All
#74
The wheel looked good, but perhaps water damage could have occurred. I never thought of that. Let me ask you a question on another matter. My turn signals won't auto cancel after a turn. I purchased a new switch (lever) and installed it but it didn't solve the problem. Other than the switch what else could it be?
#75
