'50 F1 brake/clutch assembly
Ok, I give up.....how do you disassemble the brake/clutch assembly? I need to replace the bushing for the brake pedal. I have the assembly unbolted from the truck, but now what?
I realize this is probably a really easy task but my brain is fried I think.....so ready to get this truck back on the road.
thanks for the help!!!
David
David
Wow, nothing is ever as easy as you would like to hope it would be. Thank you for the exploded diagram PanelMan. That will definitelyhelp.
Gearhead, once the head of the pin is ground off and driven out should I get a rolled pin (is that what you call them) and put in its place during the reassembly?
Why do you have to grind the head off? If the bracket is still on the truck I could see doing that, but he has it loose off the truck.
Because the pin is basically a rivet and the end(s) were heated up and smashed down like the rivets used to hold the frame together. In my case the cab was on the truck and it was a lot easier to take the whole assembly out to work on it.
Fordnut,
There's the big "pin" that slides through the brake and clutch pedal assemblies and has the grease fitting on it. Then there is a small "pin" that runs perpendicular to the big pin. the small pin is near the end with the grease fitting. If you clean around that area you should see two rivet looking heads; one on each end of the small pin. I ground one of those off and then used a punch to drive it out the other end. Once it is out, you can drive out the big pin. Hope that made sense. I have pics if you want to see them.
