Polish/ clean up aluminum jerr dann rollback bed on 89' F-350
Old 02-23-2011, 08:45 PM
stonerboys
stonerboys is offline
stonerboys is starting off with a positive reputation.
Hi, I recently bought a 1989 Ford F-350 with the 17 1/2' Jerr Dann Aluminum bed. I was wondering if anyone has ever polished one of these bed's and what cleaners/ chemicals they used and how they did it. I would like to clean the bed up a little bit more than it is to make it look better. Thanks in advance for your help.
Old 02-23-2011, 08:55 PM
96f350az's Avatar
96f350az
96f350az is offline
96f350az is gaining momentum as a positive member of FTE.96f350az is gaining momentum as a positive member of FTE.
thats alot of mothers and a couple power *****. lol
Old 02-23-2011, 09:03 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
go to any transport shop and they will probably sell you some of the acid the truckers use on the wheels/trailers or atleast tell you where to get it. mind you its not really cheap but it does an amazing job.... spray on let it sit 10-15 min pressure wash off and wow...
Old 02-24-2011, 01:00 AM
Domestic_Nuwbee's Avatar
Domestic_Nuwbee
Domestic_Nuwbee is offline
Domestic_Nuwbee is starting off with a positive reputation.
I would suggest going over it with a medium (maroon) scotch-brite pad to clean up and remove any oxidation or corrosion. Then go over it with a fine (grey) scotch-brite pad to make the grain a little finer. Keep in mind, for best results keep sanding grains uniform in one direction. Do not swirl. Now that you have a clean fresh/raw surface get yourself some MOTHERS aluminum/mag polish and a cotton rag like an old towel or face cloth. Fold up the rag a few times, load er up with mothers and go to town! Note: it turns into a black compound. With good pressure, high speed and single direction motion back and forth....you'll be blown away. Here's another tip:
I believe it says to use one cloth to polish/buff and a clean one to go over after. If you just use the one cloth and work the **** out of the mothers til the black compond is gone, you will see mirror finish results. TRUST me. Im in the metal finishing industry. Polishing/Buffing, Plating and Aluminum Anodizing is what I do. Put it this way, I have access and use industrial grade polishing compounds that are specially formulated to make it shine, but I SWEAR by MOTHERS. The stuff is amazing if used well. Goodluck, have fun. And remember to switch arms, or one arm will be more juiced than the other!!!
Old 02-24-2011, 03:40 AM
cj06's Avatar
cj06
cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
Old 02-24-2011, 05:33 AM
ArdWrknTrk
ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
We used to use a product called Alumi-Brite on the beds of the triaxles.
It kept them shiny but won't do anything for scuffs and scratches.
Wet sanding with carbide paper and then progressive polishing compounds would get it to where you could see yourself in the sides of the trucks.
Old 02-24-2011, 06:19 AM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
take it to a truck wash, and have the bed acid washed. any big truck stop has a truck wash. all that has been posted so far is good info, I also start with Pb blaster, and fine steel wool, just keep everything wet, and keep scrubbing. wipe off with soft Terri cloth towels. wear rubber gloves, on any of the products, or your hands will be stained. mothers works well, I usually add a little rain x too it, to prevent water spots. use a wax applicator pad to put the product on, a soft terry towel to wipe it off. I can do my tri axle dump in about 9 hrs, but it's a lot of work
Old 02-24-2011, 10:22 AM
96f350az's Avatar
96f350az
96f350az is offline
youll like mothers. ide sudjest a "foose" power cone to save you time and make it look better. there pricy but worth it. grab a drill and got to town.
thats what we use on dirtbike frames and wheels. we just wax it after and walk away.
just be ssure to not let the power ball get to hot. haha. itll melt off the bit. been there.
Old 02-26-2011, 10:18 PM
stonerboys
Thanks for all of your help guys!
Old 02-27-2011, 09:24 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
Like some of the other have stated.
Acid wash first.
Then get wet sand paper starting at 600 , 1000, and 1500
Do the rough spots w the 600, Then do the whole thing in 1000, then 1500.
next would be to get a power polisher and a commercial grade aluminum polish(NOT MOTHERs).
I like Speedy THE ORIGINAL SPEEDY METAL POLISH SITE. SPEEDY SHINES ALUMINUM,SILVER,COPPER,BRASS,STAINLESS STEELL, AND ALL OTHER METALS
Old 02-27-2011, 10:32 AM
ArdWrknTrk
pedant
My personal preference is Magic Mix metal polish.
Magic Mix quality polishes and waxes from Valco CIncinnati Consumer Products. The Lazy Man's Polish
I haven't found a better product, yet...
fightlivefree
04-21-2016 09:01 PM
abe
17
05-29-2014 09:30 AM
dann167
1999 to 2016 Super Duty
03-02-2014 06:59 AM
markusselanne
10-03-2011 09:24 AM
jdimassi
47
07-04-2010 06:47 AM
Quick Reply: Polish/ clean up aluminum jerr dann rollback bed on 89' F-350
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
