Blowing oil out of dip stick
I own a 1993 f-150 302 (5.0l), the engin was blowing oil out somewhere on the driver side i think from the dip stick so i changed the pvc valve thinking it was gone so when pressure built up thats where the oil could escape!! The oil stoped for a bit but now is doing the same thing! I dont know whats causeing it? Could it be valves or..? Any ideas guys
Yup, your motor is getting tired, not the end of the world. Your PCV system isn't flowing enough to pull out all the blowby, so make it flow more. Check your vent also, not just the PCV.
Don't know the exact details of the PCV system on that motor but if you look I'm sure you can find a way, just need more flow from the valve cover to the manifold. I'd suggest ditching the the actaul valve and just using a fitting, the valve restricts flow. This could effect your idle with more air flow, if so consider blocking the vent that pulls air into the engine.
Ronnief150man
04-17-2016 12:59 PM
jcweis1
03-07-2016 07:55 PM
DDPJ
10-01-2015 10:56 PM
murrhee
06-17-2009 08:46 PM
