Toyota P/S kit for 53 and up on a 52
Old 02-23-2011, 01:59 PM
special 55
special 55 is offline
special 55 is starting off with a positive reputation.
Well I have read enough of the threads to determine this is a good upgrade. I was thinking of going the kit route but all of the kits seem to be for 53 and up.
Has anyone had success using the kit on the older F1s and if so what mods did you make to accomodate the kit?
Any info is appreciated.
Thanks,
Rich
Old 02-23-2011, 06:00 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.
I don't think you need to make any mods. I think the kit works just the same. Basically there are 2 different style power steering box mounting brackets, I have pics of both styles in my gallery. They are easy enough to fab your own.
There are several hurdles when changing over to power steering;
1. box mounting bracket
2. which pump to use and how to bolt it to engine
3. hoses
4. steering column and horn
5. pitman arm
The plans for the brackets can be found here;
1949 Ford F1 4x2 - steering details
The easiest pump to use would be whatever bolts to your engine....that way there are already brackets that exist for it
Hoses aren't too bad, any hydraulic shop can fab some up. Keep in mind that the metric fittings on the pump are 2 different sizes (16mm and 17mm I think....I think the pressure side is the 17mm but don't quote me) I made my own hoses that went from standard fittings to metric
The steering column is no big deal but the horn wire is a stumbling block. The original horn wire travels up the center of the steering shaft. Once you cut the shaft to make the connection to the box then you won't be able to run the horn wire up the shaft without it getting al wound up when turning
pitman arm...I think you can buy them for the application but I'm not sure. When I did mine I made my own. I didn't mount my box in the usual location so I really can't say how bad it is
There lots of threads about the swap on here and I think even a tech article or two.
Good luck
Bobby
Old 02-23-2011, 07:29 PM
special 55
Thanks for all the detail Bobby. That's great info in your gallery.
You may have inspired me to make my own instead of buy the kit.
Thanks,
Rich
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
