rough start till warm and hick up
#61
#62
#63
Need help finding gunged , plugged up screen on IPR ,FPR?
I own a 1995 with a starting and crusing surging , loping problem . I have read on previous threds that there is a screen that can be gummed, dirty and would help alliviate my problem as I have done everything I can think of to alleviate my fiel problems . Can anyone help me locate this screen and what parts I need to remove to locate it . The odd fellow at the dealership said there is no screen to clean or pull out under the IPR or the FPR bit, I have read many on,here of the,opposite PLEASE HELP IN DETAIL IF YOU COULD
THANK YOU
TONY MARTIN HOLLY , MI.
1995 DI TSD , KENDALLMAN DUAL BAG SYSTEM , TI CHIP , 3" STAINLESS DOWN PIPE TO TAIL , US GEAR UNDERDRIVE 4:10 TO 3:55 , US GEAR INLINE EXHAUST BRAKE , NEWLY REBUILD ON E4OD WITH H.D. UPGRADE ...... MORE TO IMPROVE BUT NEED TO FIND AND CLEAN THIS SCREEN TO MOVE FORWARD THANK YOU
THANK YOU
#64
THANK YOU
THANK YOU
Pull the filter out of the fuel bowl. On the side of the fuel bowl housing is the fuel control manifold. There are 2 bolts that hold the fcm on the fuel bowl. Reach down in the fuel bowl, there is a hole about an inch down. That hole runs to the fuel vacuum-switch. You can stick a q-tip in there and it will get a good bit of it. If you really want to get it clean, pull the bolts out of the fcm, be sure not to crack the sensor or you will have to replace it or plug it. Once you pull the fcm, you will see the infamous screen. Clean it with some brake cleaner and put it back together. If you go the route to pull the fcm, on the top left side of the fcm is the fpr (fuel pressure regulator). I would seriously think about taking it apart and shimmy the regulator.
Here's a link on how to shimmy the fpr. TikiWiki : Shim Your Fuel Pressure Regulator 94-97
#65
Guess what - had the wire harness from the gpr to the starter relay on the wrong terminal on the starter relay. She starts like a charm now. Anyone wanna beat me over the head for a bone head mistake?
#66
#67
Yeah, I realized yesterday that I forgot to unlock those too... I guess I have been riding around with them locked in for a month or so now. What can I say...
handyandy123
12-16-2013 08:07 PM
frogjaw
1997 - 2003 F150
09-30-2013 04:52 PM
