Manual Transmission and Boat Towing
Alright I'm looking at getting an F250 in the next several months and am considering a manual transmission. Is there anyone out there that tows boats with a manual? My only concern is backing down the ramp and getting back up it after getting the boat in. So how does a manual preform in this situation?
I don't think there's any real advantage to a stick shift while backing a boat down a ramp.
Going back uphill I like the stick a lot better. Test drive one and drop it into the low granny gear and let the clutch out. No reason to touch the accelerator when you do, just let the clutch out nice and steady. It will get you going without any fear of having to rev the motor too much and causing the tires to spin.
I'm a big fan of this and the rest of the added control you get from the 6 speed. That said I might want the auto if I wasn't towing boats for a living!
meaning you live in the city? if you're going to be parking on steep hills, etc then it sucks...on flat ground it's not that bad. reverse is extremely slow, as is 1st gear. why dont you just do a test drive and see how you like it. it's all a matter of preference
Once you get usd to driving it you'll have no problems doing anything. I love my 6 speed, I won't have an auto.
I tow a 5ver ALOT and have launched boat many, many times with my 6spd. No complaints. Like they said, no need to touch accelerator. I also use 2wd low range all the time when backing stuff around tight spaces - its nice to be able to take my foot all the way off clutch.
Speaking of clutch... The stocker engaged smoothly and lasted 180k miles, but i swear my left leg will always be bigger from the WORKOUT. Then, i put in a LUK clutch. Much easier pedal, but kinda grabby. It get smoother over 100k miles but apparently not up to the task - the clutch disk was falling apart and friction material was gone. Currently have a SB Con OFE (dual friction - ceramic/organic linings) and love it.
