MAF (mass airflow sensor) cleanup day - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-10-2016, 08:56 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
When buying any part I tend to NOT want cheap---air filters I use nothing but NAPA's Gold line, about $20 each. Over the past 10 years those have worked perfectly, nary a sign of them failing---I do change them about 20K miles though.
Not sure who actually supplies MotorCraft with their filters but chances are its the low-ball guys. Wix and Baldwin are two names most associated with higher quality.
Quote:
Originally Posted by king-david View Post
I thought there was another thread that said that may not actually be the case? I know k&n has done some research on it and found a significant number of things that were being blamed on them, were not them at all.
http://www.knfilters.com/MAF/massair.htm
Here's something that might be new info about aftermarket air filters like K&N: http://dieseliq.com/aftermarket-air-filters
  #32
Old 05-10-2016, 09:40 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
I ran a K&N for a bit and noticed after a trip to the beach sand went right past into the MAF, immediately replaced with a Motorcraft filter. Check out the video below of comparing OEM to cheap aftermarket filters.
  #33
Old 05-12-2016, 12:10 AM
Ford4now Ford4now is offline
Ford4now is starting off with a positive reputation.
I did the cleaning tonight and I've got to say, I don't think I've spent less money or less time getting a bigger grin. Over 199K and the truck has new life. No hesitation/stumble at acceleration and gear changes come quick and easy. If you've got a bunch of miles on the odometer and you haven't done this, you gotta try it. You'll be glad you did.
  #34
Old 06-19-2016, 05:10 PM
steve454 steve454 is offline
steve454 is starting off with a positive reputation.
thanks for info maybe i need to do this, i have not used my van for awhile 2009 was last time it was on the road and now it has rough idle
WTB C&L MAF housing 19# Glaser67 WTB - Parts & other 2 06-11-2017 07:13 PM
06 Ford Expy KR Engine Failsafe Mode - No power on MAF Djeap1977 1997-2006 Expedition & Navigator 11 01-24-2017 01:46 PM
460 MAF motor- Discussion on availability cbakker Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 01-13-2017 12:12 AM
How to clean a Mass Air Flow (MAF) sensor - 5.4L CelticDevilDog 2004 - 2008 F150 18 11-03-2016 05:36 PM
Factory MAF 460 troubles Tanxjguy Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 10-18-2016 01:29 PM
Tags
00, 2000, 300, 64, air, cleaning, excursion, excurson, flow, ford, maf, mass, probems, sensor, straight, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
