92 f250 won't run when its cold
Idle air control
I have a 96 F250 with the 5.8 EFI V8 that had the same problem. The Idle Air Control Valve was replaced and all was fine. The IACV is a computer-controlled air bypass valve located in the throttle body. It helps control idle speeds by allowing air to bypass the throttle plates as to increase the idle speed.
-cheers
-cheers
If its not leaking fuel from the FPR and you have good pressure on the rail I would be looking toward the cats. a clogged or haft clogged cat wont allow the exhaust out into stalling the engine. When holding the RPMs up you have more exhaust pressure to force it threw. With no codes thats really your last to options and sence it has been getting worse slowly Im thinking cats.
From my experience aftermarket cats. ussually dont last as long as stock could try discounting the exhaust before the cat and see if it will run correct or not.
When i go out to truck it fires right up and about the time the idle drops back down (3 seconds) and starts running rough. Engine is shaking all over the place. If i hold it about 2-3 thousand rpms its alot smoother. As soon as i leave off the gas it spits and sputters and shuts off. To get it running again right away i have to hold it to the floor and you can tell its flooded.
I had a dumb moment in think the cats. I forgot it was flooding out. If I am remebering correctly the only sensors that effect the amount of fuel the ECU injects would be the ECT,IAT,O2 and the MAP Sensors. If you are not seeing codes I would haft to say the MAP sensor is the only thing left that would cause it to flood out enless there is a problem with your wiring or your ECU. The TPS could also be reading that the throttle is open father than it is but ussually they fail in the closed postion. Is it still a cold only problem or is it a constant issue now?
Its mostly to cold here right now to determine if its still only the cold issue or not. Doesn't getting alot of raw un-burnt fuel in ther exghust hurt the cat? I'm going to check the fuel regulator tomorrow after work. I did pull off the vacuum line once but never cycled the key. It had no sign of liquid in it.
The only reason it should be flooding itself out is something is telling the ECU to dump more fuel than needed. In my opinion all your symtoms point to to much fuel at idle. IE a bad sensor that involves the air or throttle readings.
