99 F-150 4.2 Litre V6 oxygen sensor dillemna "UPDATE
My trucks symptoms include a illuminated service engine soon light, sometimes a high rpm idle, and sometimes a rough irratic idle. When a scan was done it indicated the oxygen sensor was defective. The issue is: which specific one (there are multiple oxygen sensors) or how could I check or detemine the faulty one for sure. I am trying to economize and replace only the bad one myself if possible. I own a good multimeter, can it help determine the bad one? Idea's???
Shop did not agree with the oxygen sensor diagnostic so they did their own. They found a lean condition on left and right banks and said that indicated a vacuum leak. Couldn't visually find it so I gave the go ahead for a smoke test. There was a hole in a rubber elbow that went into the throttle body area. Ok, now it idles beautifully "unless" I use the AC, if I switch it on it immediately starts to surge then quits if I turn if off. Whatcha think??? Maybe a vacuum line that controls the doors in the ac system??? I didn't discover this until after I left the repair shop.
Starts to surge then quits if I turn A/C off
Bighonker, my 97 4.2l is doing the very same thing. Did you ever track down what was causing the engine surge while running the A/C. I've also noticed if I switch the hvac control to "panel" from off, I get a very noticable but temporary surge while going down the highway. Anyone else have any ideas where to look?
perforster
02-27-2007 09:36 PM
