Dome light 03 F450
Dome light 03 F450
Hello People of the internet
I have an 03 f450 with a couple electrical issues. The dome light won't turn off the dash says the doors are closed. They feel closed as well, the switch on the dash is off as well. Brought it back to the dealer where I bought it but they are to busy to look at it right away. So I took the bulb out. Fast forward several months to now I would like my dome light back. Where should I start looking for the problem?
The other problem I am haveing is the taillight fues will blow 10 seconds after I put it in. Will do this for a couple days. Then it will be fine for a month then do it again. I'm not to worried about this right now as I ordered a new aluminum flatbed to replace the steel one. So al the wiringa and lights will be changed out then.
By the way first real post other than the intro.
Cole
Cole
Is it the main dome light and not the controlled map lights? It could be a few things. The dim switch for the lights might be bad and the dome light might be stuck up. Another option is that the relay for the interior lights has gone bad. Circuits do wierd things when relays go bad. As for the rear lights, you may have some corrosion in the rear wiring harness. As for you 400nut, if the door indicator light is on as well then you might have a bad button that thinks a door is still open. Flashlights work but that is a hassle and I'm a perfectionist so I want my truck to work flawlessly in every aspect. Hopefully one of these is the culprit. Anyone please feel free to correct me if I'm wrong on something.
-Greg
-Greg
Critterhunter
1983 - 2012 Ranger & B-Series
38
05-26-2017 01:05 PM
IDIDieselJohn
06-23-2014 07:00 PM
DBray6
10-01-2006 03:22 PM
